Ok, I kind of revese engineered the rear alxe nut retaining device and torque.
Now this is the REAR nut on a Dana 80.
There was a little U shaped keeper in the axle keyway that was pushed into about 3 nylon threads that are part of the axle nut outer threads.
I got the U shaped keeper out without damage. Then I measured the nut which was a 2 9/16". Got a 1/2 drive 2 9/16" socket from the (real) auto parts store. Then I took my torque wrench and started at 120 " # (inch pounds) and tried to unscrew the nut. I increased the torque until it broke loose at 245 " # or about 20 ft #.
This is WRONG. The preload should be 120 - 140 FOOT #
SM pp Rear Axle 286RBI 3-133
The nut came off just fine. The rear hub and bearing assembly and the rotor that is bolted to same came off just fine. A little heavy, but can be gently eased off without tearing the seals. The outer bearing will fall out as you take the assembly and rotor off the axle.
I took the assembly to the machine shop and they said they could turn the rotor but would have to take out the seal to do so. I ordered 2 new seals (one for each side) for the re assembly after the rotor is turned. They turned the rotor and also turned the strip inside the rotor where the emergency brake shoes ride when applied. The machine shop checked the bearings and found DC assembles the seal with a putty type compound to seat it. The putty compound reminants would have found their way into the inner bearing so they washed the whole assembly and got all the putty residue out, cleaned the inner bearing, installed it, and put the new seal in place.
I picked up the assemblies and took them home for mounting. They fit perfectly on the axle shaft, I put the outer bearing into its race and started the outer nut on. I torqued it to 240 inch pounds and the previous cut where the nut keeper went was right at the keyway.
This is WRONG see above. It also says to NOT use the same cut in the nylon part of the nut.
That leads me to believe the 20 ft # is the right preload for the bearings.
I would like confirmation from someone else though since preload is critical.
The whole assembly seemed tight, no inner to outer play and smooth rotation around the axis. It did not seem to be binding at all.
I got one side of the axle all done with pads etc and then afternoon rains hit. I will finish the other side tommorrow.
I would like comments on the preload for the bearings though.
Bob Weis
