Rear spring spacers
Reminiscing
Best place to order an 06 in or around Colorado?
For those that have done lifts on your trucks, when you did the rear springs, the two spacers that are between the axle and the spring pack, is it possible to stack a 3rd block in there? I am going to get a Kore Pace system, so I put some jacks under the truck to lift the front 2 1/2" and the back 1" to see how it looks. I like it MUCH better than stock, but that extra 1/2" in the back would be nice. I'm assuming that the blocks have dimples to index them to the spring pack and to the axle. I'm just wondering if a 3rd will fit without screwing things up. Thanks
Well stock, the truck already has two 1/2" blocks. I have called Kore already and they said that they do go back in with their mini-packs. So, I was thinking maybe just one more... ..... :)
if you are talking about adding another stock type block to the bottom so you have 3 on bottom you can. I did with my truck, the blocks are fastened to the springs with the center bolts that hold the spring pack together. I have a 3500 srw and I just moved the third one that used to be between the main and overload packs to the bottom.
My 05 already has three on it???
