Hopefully this is posted in the correct forum:
37k on a truck that doesn't seem extreme use (I can see your eyes rolling now) or very much towing, and the carrier bearing is toast (I think). It squeaks like crazy. From my last post, I learned that Quad 4x4 carries replacement carrier bearing units for a little over $200. From what I've read and believe, I think it would be good [preventative] maintenance to replace all three of the rear U-joints (I have the 2-piece rear driveshaft). However, after doing some searching through the forums, I have found that SOME people recommend going to a one-piece rear drive shaft. If you have done this, can you PLEASE off some input!?:{
1) Approximately what kinda cash are we talking here for a truck like this?
2) Where on earth can I find a shop that I can trust to do this kind of "custom" or out of the ordinary work (I am about an hour and a half north of Dallas, TX if you wanna get that helpful!)
3) Is this the right step to be taking (aka elminating the 2-piece rear shaft) for durability over time?
If you guys/gals don't recommend going to the single-piece rear driveshaft, where should I be buying replacement OEM quality U-joints from for my current set up? I've read that the spicer and AAM units have other issues regarding fit and quality... .
what a headache! Any input is very appreciated!!
