Details here: TDR Privileges
I have no Auto-dimming rv mirror, backup lites or daytime running lites. Replaced the DRL module(Canadian Model), still not working. Can't find my shop manual for info, wondered if anyone out there could help?
Looking in my 97 manual, the back up lamp and DRL are powered thru the same fuse in the fuse block, it's a 10 amp It's #15 if that helps, by the diagram it's bottom row 2nd from the right? Hope this helps. , Cheers
Just did a bit more digging, Yup on a 97 the auto dimming miror fed thru the same point. Wire colour for all these things is brown/light green. Does your high beam indicator work?
I'm guessing that your park/neutral switch isn't working either, There is a joint connector that all this goes through multi pins, not sure how much I can help with out a tester and hands on?
