rear wheel abs
1999 3500 no overdrive
1995 12 valve fuel tank
GBax
when stopping on snow or icy roads the rear wheel anti lock brake system can activate allowing the rear wheel to continue to push you through a stop situation. Can this abs be disconnected.
Gets your heart going; doesn't it? Drum brakes or disks in the back? When the ABS triggers it releases the brake line pressure releasing all four wheels. It's a dumb system which is worse than nothing at all.
You could pull the ABS fuse or get the [drum] brakes adjusted. Or add an adjustable proportioning valve for the rear. Some years came with a load sensing proportioning valve for the rear brakes.
I disconnected the ABS controller plug so that the ABS light won't come on. If you just pull the fuse, on mine, the warning light stays illuminated.
In a '97 rear ABS, yes. A little difficult to get to but doable with the knee bolster removed.
