Have a Quad cab with 55k miles on it and am needing to istall the third set of front brake pads. . On checking the rear brake lining I find minimum wear. I do tow a 23 trvl trl and with the equallizer hitch puts very little wt on rear axle of truck.
When applying brakes on snow or ice, seems like the trl brakes are doing thir thing and the truck front brakes want to lock up and that makes for zip nadda steering. .
I have checked the rear wheel cylinders and they are one and one sixteenth dia same as on the 3500 trucks so changing them out won't do any good.
After checking out the Dodge service manual it tells of a height sensing valve which is mounted on left fram above rear axel connected with about a 14" link to the base of the L/rear shock. according the the manual when a load is loaded on truck the link pushes the arm up on the valve allowing more pressure to the rear wheel cylinders. .
My question is this... . Has anyone ever faked this thing out by splicing in an inch or two on this rod/link making the valve think there is some load on truck thus allowing more pressure to the rear whell cylinders... This valve is factory sealed and there is no adjustment for it according the the maint manual
Thanks in advance for any info on this
