rear wheel cylinders
Exciting New Tool Organizer
Help with Fueling Modules
Does anyone know who sells the oversize rear wheel brake cylinders and disc brake kits for the 2500 and 3500 rams? I thought it was a company in Canada but lost their page. My 97 has never had enough brakes.
Actually they are standard parts that you should be able to get at any parts store. Search for wheel cylinders. There was a recent post with part numbers and sizes.
If you need some part numbers let me know. Sam Peterson sent me a several MFG's part numbers for the upgraded rear wheel cylinders.
I just picked up my 1 1/16" wheel cylinders last week for ~$13 each.
I have ABS brakes, and have no experience with them. Actually a little, I push pedal, Ram stops. :D
Do most Rams have ABS brakes?
Does having ABS brakes have any bearing on installing larger wheel cylinders?
Wayne
wheel cylinders
:) :) :) Thanks guys for the help on the wheel cyls. Picked up some this A. M. . I have new master cyl and proportioning valve on order. My 97 4x4 slt ext cab diesel long bed has 111K miles and the rear brake shoes still are as thick as the new ones I bought to put on it. Not even any dust in the rivit holes, so I know they aren't working. THANKS FOR THE HELP GUYS.
dseabaugh,
Keep in mind, the rear brakes require periodic manual adjustment. The self adjusters just don't seem to work worth a crap.
Reddog1---increasing the size of the rear cylinders has no affect on the antilock brakes under most braking conditions. the increase in pressure can make the anti-lock operate more under hard braking or slick roads. the increase in braking effeciency is worth the effort. a little weight in the bed makes a big difference. ---Sam
