Details here: TDR Privileges
does anyone know if the rear axle has to be removed to change the lug studs on a 1ton dually. New member, following the TDR site for some time. Much useful information and a great bunch.
On my D350 yes. Not sure bout the 250 series. A simple job, but be sure to go with new seals. Cheap insurance to avoid leaky mess. I change brakes on my 1 ton several times a year so the studs should not be a big deal. Mike
92 Std cab. LE. 215 P-pump reman cummins motor. 5-speed, 3. 54, 105 gal Aux tank in bed. Borgeson shaft, Banks Power pack. 12cm Hot end housing w/wastegate. 4" Exh, Pyro & boost guage, oil temp guage. E-brake. Galaxy DX99V, Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, 3500 being setup for Hotshot work as we speak. 250 miles todate
