therabbittree
ok here is my deal i have a 89 4x4 srw 350 cummins with 727 transmission and 3. 08 gears... the stock convertor is too loose, and my transmission is slipping a little i think. I want to rebuild it to hold ALOT of power. as I am soon swapping to a p7100 pump with 370 injectors, enterprise delivery valves, and a #4 cam plate, amnd i'm working on a set of twin turbos... . no im doing this on a backyard budget and doing all the fabbing and work my self. I do not have the $ for a newer 47h transmission so thats out of the ?. . and the 727 is strong enough when built o hold alot of power. . ie hemis and lots of 440s use them also... . and its cheaper.
so the question is who's torque convertor do i use?... what price?. . and what transmission kit to i use to rebuild it?. . do i do a full manaul valve body? reverse shift pattern?. . etc i want to do this relatively soon... any ideas?. . ps i do like the 3. 08 gears. . and a non overdrive set is fine by me as i will be running a 4000 plus gov spring set. . and my racing deisel truck uses 3. 00 gears and a allison 3 spd no overdrive and just over 4000 rpm in a 6v53 and this runs 12 flat and possible 11's...
ok where do i get the convertor ?
where do i get the transmission kit?...
and what are your options?
thanks
deo
\x/ hillfolk!
thanks
deo
\x/ hillfolk!
