I recently became involved in a project for a friend of mine. He is rebuilding his 2004. 5 CTD. It’s a long story of how he got there but I’ll try to keep it brief. Basically at about 240k’ish miles, he noticed increased oil consumption. He really did not know what to do. Life was throwing him several curveballs and worrying about his truck was not one of them. He just monitored the oil level and kept going. This led to more and more consumption and leakage. Then another issue popped up. It started running poorly and was diagnosed as a bad #6 injector. With it replaced, there was little improvement. Additionally, we gave his truck the nickname “Puff the Magic Dragon” because of the amount of blowby coming out of the oil fill cap. It literally looked like a Choo-Choo train while running. Again life prevented him from doing anything about it until “POOF !!!”, the turbo blew a seal. The engine was running on as much 15w-40 as it was diesel. It was embarrassing watching the truck drive down the road.
At just over 260k, that was the last straw. Since it had so many issues, a rebuild is in order. He needs assistance and enlisted myself and a friend to help. The friend has a fully equipped shop. The three of us had the engine out and torn down in one very long day. The root cause of the problem seems to be broken piston rings at #1 and #6. Of course, it needs a turbo as well. The plan also calls for injectors as well as all the regular consumables like hoses, t-stat, water pump, etc. We’re even doing the Larry B’s starter contact thing since it is out.
My job in all this is to find out what is the best course of action. For that I am enlisting the help of the TDR. What I am hoping for is help regarding what tricks to do during the build. Not to make more power (of course that wouldn’t be a bad thing either) but to make it run as reliably as possible for a long long time.
So far, the turbo has been dropped off to a local diesel shop for rebuilding. I believe they are going to do the injectors as well. Also, the block, crank and head were dropped off at the machine shop today for evaluation. He is after a completely stock rebuild. No crazy power adders like my truck, he says. Are there any machining issues, tricks, etc that we need to be aware of. Should the CP3 be replaced at same time? What about the FCA too? The cam looks fine but the some of the lifters are crowned from wear. The friend with the shop says they can be machined. Is that true?
Any advice, tricks, solutions, etc would be greatly appreciated.
Thanks
Thanks
