Recommendation for power box?
ECT sensor information needed
New guy.
I'm considering adding a mild timing/fueling box to my truck or one with selectable power levels. I already have DDII's and the DD Boost Module, as well as boost and EGT gauges.
The PRIME requisite for the recommendation is that whatever box I get needs to be "plug & play". I don't want to pierce my wires or install ScotchLoks or other wiring taps.
Any suggestions?
Greg
DD box
Get the Tru Torque box from DD. While I don't have injectors yet, the box works great, has lowsmoke settings and plugs in in a couple of minutes, and is designed to work with their injectors.
Sam
Since you already have the injectors from DD I would use their version of the EZ if I were you. Its programed to meet their requests. On the mild boxes your choices are basically EZ ( DD TTPM), PowerPuck, or the VA (BD PlugNPlay). For simple plug and play (no tapping the pump wire) these are you choices. Once you get the TTPM (EZ) then you will be ablee to sell your DD Boost module since there is one in the EZ, so it will make the price of it a lil better.
