Thanks to all who replied to my first post-lots of good info. A set of gages is on my list for Santa!
Being new to this whole heavy hauling arena, I could use some advice on tire pressures. My rig is a '93 D350 LE dually extended cab with 235/85 x 16" tires and it pulls a 30' 5th wheel travel trailer. I pulled the combo (truck & trailer) onto a scale at a local truck stop. The scale was configured in 5 sections-kinda like 5 scales set up end-to-end. The total weight (13,700 lbs) was compiled from 3 of the 5 scales; both axles of the truck were on scale 1, and although I didn't take notice, from the data I presume that one trailer axle was on scale 2 & the second trailer axle was on scale 3. Scale 1 showed 8600lbs, scale 2 showed 2500 lbs, and scale 3 showed 2600 lbs. I dropped off the trailer & came back to get an empty weight for the truck, which was 6600 lbs. , all on scale 1.
These numbers surprised me. I never would have guessed that I had 2000 lbs tongue weight-the truck doesn't seem to settle that much with the load. That's also a little more than 28% of the total load, well over the 10-15% that I've heard is the general rule of thumb for tongue weight. The trailer weight was a big surprise too, seeing that both the previous owner & the NADA listing for the trailer stated its weight was 4200 lbs. Since then I've done some research, and actually, 7100 lbs for a 5th wheel this long is kinda on the low side. Makes me wonder if the truck scale was accurate?!
Back to tire pressures. While driving the rig back from AL to MO (mostly interstate, 60-65 mph) I was monitoring the tire's temperatures , and they always were just warm to the touch-maybe 85-90 deg F. I recall the tire pressure being around 40 psi. I've read that the way to determine correct tire pressure is to take a reading when cold & then take another when up to operation temp, like after a 15-20 mile jaunt at speed. The correct cold pressure is arrived at when you achieve a 10% increase from cold to operating pressure. Sounds like a good plan, but I always forget to take the hot pressure- Doh!
I would appreciate any input. Hopefully it might influence my fuel economy & extend my tire life. Thanks for your time!
Joe Jump
St Louis
P. S. Stupid Newbie Question: How do you attach your truck profile to the end of a message?
Joe Jump
St Louis
