I have a 2015 3500 Laramie Longhorn dually and I'm about to install the Recon Big Rig Ice lights. My question is where to tap in for the ice light function. I need to know what wire, and where to find it, for the interior lights. TIA
The courtesy light wire should be running up the A pillar. I'll have my headliner down this weekend and will be able to check the wire color.I installed the lights (but didn't hook up the ice function yet) and they were immediately problematic. After calling Recon, I was told that I would need to install the diodes that were included in the kit. Well, I hadn't seen any diodes with the kit, so I started digging...into the original packaging...thankfully, I had saved it. I couldn't see to the end of the box and shaking it yielded no sound, so I sliced the box open along it's length. The plastic bag with the diodes, connectors and instructions was actually taped to the inside of the box at the opposite end from where I had opened it (of course). After installing the diodes (very easy) the lights are now working perfect....except for the ice function. I have no desire to remove my door panels to hook up these lights, and I don't think it should be necessary..maybe I'm wrong, but I'm hoping there's a fuse that I can tap into under the hood to power the ice function.
