ok, so i have had the smoke lenses on the cab clearance lights for less than a year (11 months) today i left the truck running as i went into the store. on my way ought i figured since it was dark out i would check all of my lights. first thing i see is my drivers side outter cab light is "burnt out"
not a big deal, ill buy a new bulb and replace it. just now i wanted to verify it was the bulb. nope. the bulb works fine. so does the socket it is in if you wiggle it just the right way. not a big deal, when i have more time i can fix the socket with some tricks.
the thing i cant fix is the fact EVERY light cover is cracked. i tightened them down as follows.
place cover on roof.
insert screw and turn.
once screw head has contacted light stop turning
i dont feel i over tightened them as i was VERY cautious of this.
what the main problem is i can not find any contact info for this company...
does anyone have any insite?
thanks
Grant
thanks
Grant
