Sorry 'bout that! Didn't pay attention to your name, just your "handle".
If it doesn't work now your best bet is to get an aftermarket cruise control and go from there.
If you really want to keep it stock, you will have to get a OEM manual for the Ford, and determine what wiring is needed for it, figure out what's broke (since it didn't work before) and go from there.
On E-Greed there are kits for cruise for Fords that don't have them. I'm not going to say "all" but every '97 I've worked on has been wired for cruise even when it's not factory installed. So the kits are a way of getting the rest of the needed pieces. Now, I've not worked on a 95 for a long time what I don't remember, but feel it does, is ... does it link to the OEM PCM - I believe it does - meaning you need an aftermarket unit or ... you need to do a lot of "customizing" to get it to work.
Hope that helps.
Dan
