Red is yellow, black is green? need printer help..
An Iraqi I would want as a neighbor
email attachments
Swapped in new cartridges, it still is printing this way.
Black is actually fluorecent green, red is bright yellow.
No other colors.
arrrgggghhhhhhh!!!!!!!!!!!!!!
Help!:rolleyes:
Gene..... been hittin' the propane bottle again huh? :-laf
Could be a defective cartridge.
I had one a month ago that printed everything red.
swapped out for a new, new one ..... everything's Okie-Dokie.
Quality control just ain't what it used to be. :rolleyes:
It's a good bet. Gene's printer is not printing magenta, which will turn red into yellow (yellow+magenta=red; no magenta=yellow) and black into green (cyan+magenta+yellow=black; no magenta=green [cyan is a blue])
Oops. Sorry for putting y'all to sleep with this techno-babble!
Fest3er
If it is an older printer run a head cleaning if possible my printer did some crazy stuff like that untill I cleaned the head.
Craig
Try running it through 3 or 4 head cleanings. It's possable that the old colors are still stuck in the nozzles. Either that or the cartridge is bad, like everyone has already said. :rolleyes: How old is your printer?
Scott
They make/model of the printer could help a lot too... .
We still don't know if this sucker is a bubble or ink jet... .
A lot of the more modern ink jets have replaceable nozzle/cartridge assemblies - making cleaning the jets unnecessary when purchasing a new cartridge.
You do have to align them - but that's beside the point.
Gene's truck voodoo has finally transferred to printers!! What's next - cellphones and PDA's?!! :-laf
Matt
No, no, Radixr is colorblind, remeber he always was in GLTDR chat in bright pink?
Inkjet HP 722 C
It has printed alot over the alst three years, not much lately.
My Compaq did this and I never did figure it out. I finally kicked it to the side. I still have it but don't use it.
Are there two cartridges? One black, one color? Get on HP.com and go through their online trouble-shooting process. I had a different problem a while back and that fixed it right up although I didn't think what it was having me do to it would amount to anything.
I also have a 722c on the fritz. Mine wont print yellow. All the pictures come out blue tinted. I've tried 2 different new color catridges and neither helped. For the price I paid for the ink, I can get a whole new printer and ink to go with it. I think printers are becoming a disposible item. I talked to a salesman who worked at CompUSA and he said they take a beating on new printers and hope to break even selling the ink. :rolleyes:
Try this Gene. . Pull out the ink cartridges and use an eraser (pencil eraser. . not a chalk board eraser) on the copper connectors on the back of the cartridge and put it back in. If that don't work, rub an alchohol swab, or a handy-wipe across the print head. If that don't work, run the print head cleaning/priming feature for the printer a half dozen times.
If none of this works, have Radixr come over and verify that you are really not color blind.
Doc
Since we are into printer problems. .
If you have problems with the printer not picking up the paper, the roller probably has too much paper lint on it. Clean off the lint by rubbing a large pink eraser back-and-forth over the roller, while you slowly turn it.
Doc
