I was impressed with this part,
Red-Head Steering Gears Inc. Remanufacturing Manual Steering Gears & Power Steering Gears since 1981.
Manual & Power Steering Gears
Rack & Pinions, Power Rams, and Control Valves
Home About Us Remanufacturing Process FAQ Inventory
Red-Head Steering Gears Remanufacturing Process
Machining out the housings and installing needle bearings
Flamespraying or replacing the shafts as needed
Installing new control valves on some applications
Custom fitting each worm & piston assembly with special ordered, precise oversized ball bearings
Other things we do to produce a top quality product include: Install every sector shaft on a lathe to check for straight and true, polish the sealing surface to a higher polish than new.
Some original housings are manufactured without bushing or bearings. This is commonly seen in some Ford gears and Chrysler Corp. gears. We rebore these units and install needle bearings.
We use only the highest quality seals. All our seals are either O. E. M. or produced by two high quality, long time suppliers of our industry.
There is no substitute for experience. Harvey, the owner and lead technician, has been remanufacturing steering gears for 21 years and many, many thousands of units.
Probably the most unique and important thing we do is custom fit every single worm and piston assembly with new precision fit steel balls. This is a process not matched by any other company in the industry. This process is very important. The machining tolerances of the original manufacturing leave a small and varying amount of play that can be corrected in no other way.
Why don't other builders do this? It is expensive and time consuming to set up. This is one of the reasons you may find another unit somewhere else for less money but the quality cannot be beat. This is why we proudly declare that we are "Not the Biggest... Just the Best!"
We also stock what we have found to be the highest quality RACK and PINION units available. Although these units are not built in-house, we have selected the highest quality manufacturer and product we could find. They have the most comprehensive testing process in the business.
