Reflections in pillar gauge
Water in intercooler?
US Gear Exhaust Brake Installation Tips?
Juat installed 3 gauge pillar mount. now I have the lowest gauge reflecting the back window ( and everthing it sees through the windshield ) making reading the gauge difficult, this was in daylight I think it will be impossible at night with head lites reflecting back. #ad
Any suggestions??????????
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter onboard. Taylor Wing and Gear Vendors on order
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
Wait a minute... the gauge is reflecting what you see in the back window, which is reflecting what you see in the front window? It would seem that the driver would block the bottom gauge from reflecting anything. Can you put a slighty different angle on the gauge pod? That would change the reflection angle.
2001, 3500, 5sp, 3. 54LS, 4x4, pyro and boost on the A-pillar, 165 watt backup lights, Thomas powered on-board air system, Grovers.
The top 2 gauges are mounted at the same angle as the 2 gauge pod but the bottom gauge is set more angled to the right. My seat is set farther forward than most so I block a little of the reflection but if the seat is even with the center section the whole gauge face reflecting the rear window.
Quality of the gauge works 3 gauge w/ tweeter is not as good as the 2 gauge pod. The hole for the tweeter is too large and the tweeter does not snap in tight, you can pull it out.
