Regen Frequency following S87 SCR Recall
Been some time but I'm back and looking for your expertise!
Regen notice
Has anyone else noticed an increase in regen frequency since they had the S87 recall done? My '14 truck used to only regen maybe once ever 3-4 months (I know when it regens from the CTS insight display). Truck now has 63,000 on it...Recall was done at around 55,000 or so.
Past summers when I was pulling my 5th wheel camper, the truck would not go into a regen cycle all summer... and I had never seen it regen while pulling the camper. This summer, it has regened 4 times this summer and it even regened about a month ago while towing the 5th wheel down the interstate.
I am a bit nervous that I have some kind of an issue causing the increase in frequency, or perhaps they changed programming so that it regen'd more often?
I've kept records on Active Regens form new on all My Trucks, and yes its more frequent after update and runs 75-125F higher Max temps during those Active Regens, shorthorn all is good keep driving normally , but if you must shutdown at Peak DPF Temps 1100-1250f just let it run for 2 minutes after it turns off.
