Remote entry system ?
Hi-Temp Anti-Seize
Comp and a Code
Does anyone know if the power door locks on a 97 work with a negative (-) trigger (output) for an aftermarket keyless entry system?
Thanks
Our Dodges use whats called a reversal rest at ground system. I have the diagram to wire it with 2 relays, its not hard if you have a little experience with relays. If you don't want to try it I'll wire up 2 for you and mail them to you. It would cost about 8-10 for the relays and the harness. I can try to email the diagrams for you if you would like. Just let me know.
SteveOo.
thanks
I'll order up 2 relays with the system.
If it's not too much trouble, the diagrams would be nice.
my e-mail is
-- email address removed --
regards
