I installed a Valant remote start keyless entry in my '95 and have been happy. I bought it just for the keyless entry on sale from JC Whitney($39)but after seeing everything it would do ended up connecting everything. It has a diesel mode switch that will do the wait to start heater cycle,which I don't use because I plug in the block heater. You can adjust the crank time and how long it will run after being started remotely. Another feature that I use a lot in the winter is that you can remove the key, lock doors and leave it running,if anyone tries to move it it will shut down,you can also shut down remotely. You can also program it to start the engine every hour and run for 10 or 20 minutes to keep it warm,not really a good idea with a Cummins. It flashes parking lights when locking or unlocking doors,p. lights stay on when it is remote started,if the hood is open the remote start is disabled so a mechcanic doesn't get hurt. Remote works from 300ft,it had one more button to open a trunk,I connected it to the horn relay,makes it easy to find where you parked. Only bad thing is once I forgot to plug the block heater in, since I had the wait to start feature turned off and can't hear the truck running from my house,it kept trying to start the truck once a minute till the battery ran down. You can download wiring diagrams/color codes for any rig from their website,it was right on for my 2500. This electronic marvel was normally $79 and considering everything it will do it's worth it even at the higher price. Took me 6 hours to install,but I soldered and heat shrunk all the connections,there's lots of them(at least 25). I'd do it again on a new truck,it's worth it to me. For automatics only.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(Play truck)95 3500,5 speed,Driftwood,Banks&Phscotty,34,000 GCVW apple and tractor hauler(work truck)
[This message has been edited by illflem (edited 11-29-2000). ]
