Engine/Transmission (1998.5 - 2002) Removal Dash Trim
Engine/Transmission (1994 - 1998) P.o.s.
Engine/Transmission (1998.5 - 2002) Recalls
HEY GUYS NEED SOME HELP GOING TO INSTALL FUEL PRESSURE GAUGE IN DASH WHERE SUN GLASSES GO ETC 99 2500 CUMMINGS QUESTION DOES THE TRIM AROUND THE RADIO / SPEED ODOMETER ETC SNAP IN PLACE OR DOES IT HAVE SCREWS SOME WHERE DON'T WANT TO BREAK IT THANKS QUESTION # 2 SENDING UNIT THAT GOES ON TOP OF FUEL FILTER STANDING IN FRONT OF TRUCK WHICH HOLE DOES IT GO TO THE LEFT OR RIGHT PLUS A ELBOW CAME WITH IT DO I NEED TO USE IT OR JUST SCREW IT IN STRAIGHT UP THANKS . PLUS POWER SUPPLY CAN I TAP IN TO CIGARETTE LIGHTER POWER THANKS
The trim just pops on. There are about 12 spring clips that hold it in place. Pry a little at a time slowly and you shouldn't have any trouble. As for the fuel gauge... . I have a 2001 so I'm of little help with that part.
Mark
On the '98 I had there was one screw to be removed around the cubby hole, air bag disable area, I don't know about the '99. My 2001 does not have a screw, it just pulls off and snaps back on, nothing to break. Don't know about the sending unit, I tapped into the schrader valve before my fuel filter, and the cigar lighter power is good.
Ron
mine is a 99 and it just pulls off, no screws to worry about. Like was stated earlier go slow but you will probably have to use a bit of force, mine is tough to get off. The other note of caution I would put out is to be careful snapping it back on afterward, I cracked the clear plastic bezel over the gauges by being too hard pushing the trim back on after I was done putting in my new stereo. Go slow and it is a very simple job.
