I have a 2011 Dodge/RAM 3500 DRW with the Laramie/Longhorn appearance package which includes 4 Alcoa aluminum wheels. Painted steel rims are on each inside dual
wheel. About 2 years ago I noticed a whitish substance around the valve stem on the aluminum rims. Further investigation determined it was filiform corrosion. It occurs on the aluminum surface under the clear coat. Internet searches produced some possible solutions on removing the corrosion using penetrating oil and then using steel wool on the corroded area. The corrosion is actually magnesium oxide and originates from the magnesium that is a component of the aluminum alloy in the wheel. This method may remove the corrosion, however, the wheel will no longer have the clear coat that would prevent further corrosion or oxidation of the aluminum itself. Over time, the area will darken and require continuous maintenance. Does any one else have this problem and how have you dealt with it? I have asked my dealer to submit an inquiry to FCA customer service and we are awaiting an answer. Since Alcoa was the OEM supplier to RAM, perhaps they have a remedy. I'd like to hear from others who have this condition and how they fixed it. By coincidence, I have an Airstream travel trailer with an aluminum skin. Small patches of filiform corrosion have also appeared. Airstream suggests cleaning off the corroded area with a light pumice paste using a tooth brush. Then thoroughly clean the surface with isopropyl alcohol. They sell a "clear coat" pen similar to a wide felt tip pen with a clear coat in the reservoir of the pen. Apply the pen to the cleaned area. It seems to work OK but time will tell.
