I was messing with this last night, and didn't get back to it today due to other projects... I got the HX-35 off, and have been trying to get the downpipe off, so I can install the new downpipe and HX-40.
I've almost mangled the existing downpipe... I drilled a half-inch hole through it and have been trying to hammer it out using a screwdriver and a 2 lb. sledge. This has resulted in elongating the hole on the bottom to almost two inches long, and only gotten the pipe loose by about 1/2 to 3/4 inch.
I was about to get a Sawzall and start cutting, but I'd rather not mangle the pipe beyond use (at least the holes can be patched in case I want to reuse it later).
Then a friend said to use a propane torch to heat the pipe and it'd slide out. Is this true? I can't get it to budge. It won't rotate either. It appears that the darn clamp has put a small dent in the top of the pipe, which may be preventing it from sliding out.
I've already soaked it with Liquid Wrench several times, and that hasn't helped much either. The only other thing I can think of is to remove the entire exhaust system, but I imagine the rest of the slip-fittings will be just as stuck.
Any suggestions?
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, HX-40, Southbend Clutch, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
Any suggestions?
Rob
