Unbolting and removing the transfer case from the G56t took only 30 minutes with the bulk of the time and ONLY frustration spent trying to remove the nut at 1 oclock (looking toward the front of the truck from behind the TC.
The LONG heat shield running above the exhaust pipe meant that I could only use a 1/4" drive ratchet in order to get any throw and also the depth of the stud meant I had to use a 3/8" drive 12 point reduced to 1/4" in order to get onto the nut but the ratchet couldn't back up enough to get the nut entirely off the stud without pulling the TC back a bit first. In other words, it's SILLY design that demands just the right socket on a short 1/4" ratchet drive !!! I'm definitely going to nip about a 2" corner of the heat shield closest to the bell housing off to make installing it back MUCH easier with a ratchet wrench.
Once the TC was off, I jury rigged an 8 x 8 and a couple of 2x8s onto the floor jack by drilling a two holes aligned to accept the transmission crossmember studs as well as a 5" x 1/2" deep hole in one of the 2x8s to accept the puck on the floor jack. The hole should be centers right where the bell housing and the gear housing bolt together.
Then I simply ratchet strapped the G56 in 2 places, at the rear and at the shift point, in order to snug it to the 8 x 8 and rolled the floor jack backwards while watching for clearance at the transmission tunnel.
Once I had loosened all of them by hand, the bell housing bolts were easy enough to back out using an impact driver and a LONG 3/8" extensions with a flex joint at the socket to get at the bolts from all the way behind the transmission.
The hardest part was sneaking the bell housing past the exhaust support/bushing bracket, so I ended up pulling out the bushing from the bracket and then was able to swing the bracket out of the way. If Dodge had simply reversed the orientation of the bracket welded on the exhaust down tube, it would have been a simple matter to just slide the whole bracket back with the transmission on the floor jack.
