HI All,
Both of my work trucks are not working... .
I don't know if it is the lack of lubricity in the new low sulphur fuels but two of my trucks have recently started having trouble turning off... I. E. the little plunger that shuts the fuel off does not always turn the truck off with the key so I have to manually flip the lever on the pump to shut it off... This isn't necessarily the end of the world BUT sometimes the fuel cut off plunger will shut the truck off BUT stick in the closed position and not allow the truck to start... THAT is a big problem... especially when it happens far from home.
Given that, I had the local shop removed the guts on the electric fuel shut off plunger and use a regular choke cable to pull the fuel shut off lever.
The removal of the guts solved the problem on one of my trucks (the 1989) so I decided to have the removal procedure done to my other work truck (a 1991)...
As fate would have it, the 1991 was on a job and refused to start before having the removal procedure done... . The mechanic that removed the guts on the fuel cut off solenoid on my 1989 truck was nice enough to ride out and get the 1991 running.
We took the truck back to the shop (no problems once he got it running), the mechanic removed the guts as he had done on the 1989 and even went a little further and changed out the fuel filter too.
I went to get the truck BUT now the truck won't run much above idle despite manually moving the throttle... . even as far as wide open!
The truck starts and idles fine but won't make any appreciable RPMs... . NO smoking or rough running... . just won't build RPMs.
I thought maybe air in the system BUT since it runs smoothly can I rule this out?... . The mechanic said he bled everything.
The injector pump was replaced not too long back on this truck (1991)... .
Weird thing is the truck ran fine getting back to the shop before the guts were removed (electric plunger parts removed) and fuel filter changed out now the truck is not usable... .
Any Ideas on why no RPM's?... .
Please help since now BOTH my work trucks are dead in the water (In all fairness tho the 1989 does run OK but the new replacement Jasper transmission just gave out... . AARG).
Thanks in advance for any and all help.
Andrew
Andrew
