The bodyside moldings are easily removed with a heat gun. Keep the heat gun constantly moving across the molding until it is hot to the touch. Start at one end, lifting with your fingernails and the molding will peel right off.
The bodyside molding from a SWB '98/'99 Ram can be addded behind the rear wheelwell of the LWB Ram for extra protection or to give your ride that "completed" look. I did that on my Black Sport... until I removed them (Doh!) to install my Mopar fender flares. You can get away with a lot of things like this on a Black vehicle. Most Rammers never even notice I have added the bodyside moldings to my Sport. Hidden in plain site. . Ram camo.
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille & valve cover, '00 Sport headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Prime-Loc, Amsoil Dual Remote Bypass, Optima Yellow Tops, Bosch 275s, VA CPC, (censored), Aeroquip braided s/s fuel lines, Banks 14 cm2 turbine housing/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & valve body, BD trans. front pump & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
