I've never taken rear dually wheels off. I was told that the inner wheels "slide off" after the outer ones are removed. Is this correct, or is there anything more to this procedure?
Thanks!
Thanks!
Originally posted by GFritsch
Tips on airing up the inners? Rotation Tips?
Thanks in advance
Sorry, Yes they just slide off on all dully trucks I have seen.
Originally posted by dpuckett
PCarbonaro-
There should be two small studs coming out of the hub that are used to align the wheels upon reinstallation. Make sure the studs line up with the holes in the rims, or things will be askew. Or do the 2nd Gens even have the alignment studs?
The valve stems should be 180deg apart if installed correctly, with 2-3 threads showing at the end of the lug nuts after tightening.
Daniel
Originally posted by metal tech
PCarbonaro, I realize that you have already removed & replaced the duals, but this is just a thought to prevent future headaches. I apply anti-seize to both the hub and each dual wheel where they go together. This prevents rust from making them almost impossible to remove. Being from Jersey I'm sure you get your share of snow/salt/ect.
Al
