HOw i removed the decals. took "goop" wet down the tape that holds all on. Then took fishing line, used 4lb, just because i had it. Used a sawing motion to cut thru tape between paint and decal. After that was done. now you will have just the tape remaining on truck. Wet it down again with the goop you will see it get the wet look. I then used finger (side) to start and lift up the actual tape. Once i had a, start then i just kept pulling it up to remove it. Start on small decal first to get the feel. I started on Larime. Have side 3500 to remove still. Note: i did try a heat gun. Got the decal so hot i could not touch it bare handed. the heavy duty truck decal is very thin and can break. Also "WD40" will clean and actually help in removal of stickum. control your wish to get it done quick, do not take a blade to it. pick one and take just it off. sit in a chair to do this. Think of how it will look clean as a virgins ... ... ... ... ... muhaa!
