zstroken said:How involved is it? Do i have to take apart the show axle? Can I slide the axles far enough out to get the carrier out without taking off the outer axles?
steved said:Then you will most likely need to use a prybar to get the carrier out as they are in the housing under preload for the carrier bearings...
steved
rbattelle said:What kind of adjustments (if any) are required when the carrier is reinstalled?
-Ryan
JGheen said:Thats odd, when I removed my carrier it pretty much just fell out. No pry bar needed. It was in there pretty good but you had to make sure it was perfectly straight pulling it out by hand and it just dropped out. I have seen others using a housing spreader but maybe that's just a characteristic of the 2500 Dana 60![]()
Joe
Joe
