Engine/Transmission (1994 - 1998) Removing grid heater?
What is the best way to get rid of the grid heater? It looks like its all one solid piece ? I have seen in pictures ones without?
I don't know but why do you want to get rid of the grid heater? Mine would have a tough time starting if I didn't have it. It is +3F here in Pittsburgh Pa!!!!!
take the intake plate off the block, and the grid is held in there with some bolts, remove them and the grids will come out, i took my off and it dosnt have that hard of a time starting. plus you get more air flow. any more questions just ask.
How much air flow is there to be gained by removing the grids? I mean, is there a measurable about of EGT reduction to be seen by removing them?
I couldn't tell you numbers but I am told significant air flow is gained by taking the grid heater off. The reason most people don't do it obviously is because of the cold weather issue.
Yea, its understandable why you would want to keep them. I was just curious as to what kind of gains could be seen. After doing my Cummins conversion, I never hooked the grids up, and the truck will start down to 8 or 9 degrees (coldest ive ever tried to start it being unplugged) without much fuss. Another second or two of cranking, and a few seconds of shaking and rattling and she's hittin on all 6. Maybe someone else will add their 2 cents about the issue.
On one of my engines, I removed the grid heater element from the grid heater/spacer. It's held in with 4 studs/bolts. Each hole is already the right hole size to run a 1/8npt tap in. Tap each one, plug them with pipe plugs. Then you got ports to use for ... you name it.
