rbattelle
I've got about 20 ft of 2x4x11ga hot rolled A36 that I'm working with. In the past, I've removed mill scale using a sanding disk on my angle grinder.
But this 2x4 stuff has some extreme scale on it. Rather than being black and grimy like the other stuff I've dealt with, this stuff is a medium gray color and is absolutely impervious to everything except a grinding wheel (I've tried a wire wheel, knotted cup, various sanding disks, a flap disk, and acetone).
I'd rather not use a grinding wheel because it introduces surface imperfections I'd prefer to avoid and it will take me a lifetime to remove all the scale from that much steel.
I've heard of 2 commonly available chemical methods: muriatic acid and vinegar. I'd rather avoid the muriatic acid because of the danger and the large volumes I'd need for this job. But before I go invest in several gallons of vinegar, I thought I'd do a little research.
This page suggests mill scale should not be removed, because it forms a protective coating. But most paint manufacturers say it must be removed prior to painting (I will be painting the steel after it's assembled).
I am welding this steel, and it seems to me that the scale doesn't conduct as well as bare metal does.
So what, exactly, is the harm in leaving mill scale in place? It seems to me that it seals the steel and prevents rust (which is good). Is paint adhesion the only reason to remove it? If so, then it's a non-issue for me to leave it on.
Ryan
Ryan
