photowrite
I've done a search both here and on other forums, think I know the answer, but would like to be really sure before ordering a bumper.
My truck is a 2014 2500, G56 6-speed, with the factory class 5 hitch receiver. I love the stout stock hitch, but because I would like both a bit more clearance for the 35" spare I have stuffed under the truck, and a heavy-duty bumper, I will likely replace both the stock bumper and hitch with an aftermarket towing bumper (15K rated Reunel).
Q. Does the factory class 5 hitch just unbolt?
I've been under the truck many times looking and studying... It appears there are two C-shaped plates that sandwich the frame and secure the rear hitch. It looks like the main, central hitch tube is welded to the inner C-section...which makes it look like the hitch is welded-on, not bolted. But I think the hitch is just welded to the inner C-mount? Looks like there are captive nuts on the inside of the frame, with bolts running from the outside, in, to hold the hitch C-plates together.
Has anyone removed the OE hitch/bumper on one of the latest model trucks? Do they just unbolt as one would hope?
I was going to remove the hitch receiver this past weekend just to confirm before ordering the bumper, but when I saw that the stock bumper attaches to some of the hitch mounts, I realized I didn't want to remove the hitch/bumper until I was ready to replace both.
Thanks for input.
Thanks for input.
