TRAMPLINEMAN said:I really don't see a problem doing this. But, you'll probably have to fab up a couple extra brackets.
redram said:The seat unbolts very easily. The brackets had to have the factory rivets drilled out.
Yes - it will leave the four brackets that will be coming off of the two tunnel side front seat bases / brackets.Forrest said:... Can the seat be unbolted w/o having to remove anything?
thanks
redram said:Wrong, on a 96, the front middle seat back pivots on the bottom seat and the bottom seat cushion is bolted to brackets that are riveted to the two inside front seat brackets that bolt to the floor.
