I have a 1995 3500 2wd. I thinking about a set of compound turbos that needs the cooler lines removed. The most I will be towing is 3,000lbs. I have searched TDR about this and found that some folks think it would be a mistake to remove the stock setup, yet others have and it sounded sucessful.
I would run the stock cooler in front of the radiator and a fan cooled plate cooler that is rated at 26,500 GVW with a fan thermostat.
Does anyone have any advice on this?
Thanks
Thanks
