Engine/Transmission (1998.5 - 2002) renew antifreze.
Engine/Transmission (1998.5 - 2002) Problem solving
Engine/Transmission (1998.5 - 2002) no start when warm
On 2001 diesel, is there a one way vale on the engine to remove air from the system when filling with new antifreeze, if so where on the engine is it located. Thanks
Ive filled mine in years past (after flushing) by simply adding coolant to the radiator with the t stat removed until the coolant level reaches that point. Generally you will see some air bubbles coming up, I will slowly add until no more bubbles and coolant is at tstat level then drop t stat in, housing, and upper hose, then finish filling and top off resevoir bottle. Then start the truck and run at high idle for a few minutes, and top off again. Its always a good idea to check the level after a short trip, may need to add a little more. I generally flush my truck like this every 2 years.
