My 07 5. 9 is taking longer crank times mostly when the engine is already warm. Sometimes in the morning on the first start it takes longer to crank as well. From what I have read this is due to failing injectors. I was wondering if just replacing the tips would solve this problem or if I need to replace the whole injector body? Or could this be caused from something else besides the injectors? My truck has 116k on it. Im also running a Smarty on SW9. (I know whoever is reading this is probably cringing about the SW9). I keep a good eye on the pyro guage tho (I get out of the throttle at or before 1200). I have the injection timing and rail pressure settings set on mild in the program. Thanks in advance!!!
