I'm looking at replacing the entire rear axle on my 93 2500 with one from a 2003 truck. Idea is to get disc brakes, this would rediuce me crawling under the truck regularly to adjust up the existing drums, and simplify maintenance. Frame widths and spring perch appear the same.
E-brake: not going to use (I use a 'micro-lock' on all four wheels now - the E-brake didn't hold when recovery winching stuck chevys)
Question is ABS: My truck has the single diff mounted sensor, 2003 has twin wheel (hub?) mount sensors. Do we hook one up (as suggested by local Dodge service tech) or can we get rid of the ABS totally... . i. e. remove 'extras' below master cylinder and light bulb from ABS on dash?
Next, Master cylinder. Some say original works, others say no. Has anyone tried this? Is there a replacement that is compatable with the disc brakes and the vacum booster on the truck (I wondered if maybe a master from a 2003 gas-burner?) Or an upgrade to a later year boost-pac. . ?
What do you all think, headed for trouble or is still as simple as I first was thinking?!?!
