Engine/Transmission (1998.5 - 2002) Replace turbo for HY35
Engine/Transmission (1994 - 1998) Rebuild automatic trans
2nd Gen Non-Engine/Transmission 2 Different Shoes for Rear Brakes?
I ran accross this cummings turbo for sale, in near new.
Hear the numbers can some tell me if this is a HX35 that i can use to replace my HY35
Assy #3533320 Ser #co2853302 Type #WH1C
Thanks to all
JOe
I am not sure if that CUMMINGS turbo will work on a CUMMINS engine, but if it wont I might have a PDR HX 35- 12cm2 housing for sale,
Cheers, Bill
Easy way to tell a HX from a HY is to look at the wastegate actuator. The HX has a rubber hose that attaches to it and the HY has a small right angle steel line.
Chris
The model H1C is the type turbo that was used on the 1st gen trucks with nonwastegated housings. Does this one even have a wastegate? I know some people have put the HX35's wastegated housing on it,so it must be very similar or the same as the later HX35,at least on the compressor side.
Thanks to all
JOe
Joe,
My '94 CTD is OEM equipped with the WH1C Holset turbo and I'm told that it is functionally the same as the HX35. I recently recently purchased a new W1HC with a 14cm housing and believe that the exhaust housings will interchange with the 1rst Generation H1C turbos and all the HX35. HTH's, Larry
Originally posted by Cummins4Life
What is the max reliable boost number for a stock HY35?:confused:
"Reliable" is completely subjective... but to keep drive pressure at sane levels... . 25-30 psi of boost is the absolute max!
I am going to buy a HX35
Hi
I got offered a near new complete HX35 off 2000 that been wrecked for $400, any comments. thanks
