Engine/Transmission (1998.5 - 2002) Replace VP44 pump wires ??
Engine/Transmission (1998.5 - 2002) engine sometimes stalls
Engine/Transmission (1998.5 - 2002) Clutch Change
Has anybody attempted to replace the pump wires that were pierced/soldered to use a fueling box?? Can this be done?? I have a pump going bad that SHOULD be covered under warranty, but since the wire had been pierced, well, you know.
Tx,
Rob G
2001. 5 Auto 4x4 TST Comp and that's it !!:rolleyes:
I don't think you can
I don't think you can. You might try telling them the whole story and see what happens. It worked for me. You may want to have around $2K handy in case it doesn't.
They can tell if it's been tampered w/.
Good luck, Wiredawg
I replace my wires in may and had my pump warranted. It is not very hard you just need a good set of wires off of a pump
SHOULD be?
Not quite sure of why a modified pump should be covered. :rolleyes: If you want to play, you better be prepared to pay for the consequences.
Heck I had to replace the wire on my pump just last week. The dang thing fell apart in my hands. :eek:
I just soldered in a good peace of 16 gauge fuel and heat resistant wire and then soldered a wire with a connector onto that. Used heat shrink tubing and some electrical tape and a little Di eletrical grease on the connections and it looks real nice. Now I have a quick change capability on my fueling boxes. :) I can switch back and forth between the PM3 Comp and the Edge Drag Comp in just a few minutes and don't have to worry about no crappy scotch lock connector. ;)
By the way I totally agree "you play you pay" don't try and pull one over on the dealer. Just walking in and bend over and take it like a man for the new pump. :cool:
DB
