replaced oil filler cap with breather cap....
91 250 4x4 truck Q's
What exhaust size and muffler
and my oil leakage at the rear seal by 75% !!! Now I'll put off replacing the seal a while longer.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N, cleaned-up exhaust with Dynomax straight-thru, rebuilt injector pump, thermostatically controlled twin 14" Permacool electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, Reese Titan 2. 5" receiver, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
That sounds like there might be an obstruction in your factory breather tube that exits on the left side of the engine under the fuel filter. If it were working then changing to a breather on the filler cap shouldn't make a difference in crankcase pressure.
Just a thought, might be worth checking out.
Good luck,
Caleb
1993 LE W250 4x4 CC,Auto,3. 5's,LS. . Diamondplate,PowerWagon injectors,K&N,Egt,Boost,trans temp VDO Vision series, BD 3 1/2" Exhaust, 16cm housing,Mag Hytec Diff+ Trans pans,Transgo TFOD shift kit,Roadmaster Active Suspension.
Caleb Reese (per forum guidelines)
no obstruction there; just more blowby than it can handle! I suspect such is the case with a lot of Cummins judging by the amount of spray they generate out of the vent tube!
Jesus</A> saves!
Boosting the earlier models at higher levels tends to up the blow-by more than the new versions, the rings were updated in the new series. I don't know when however, BigDon knows for sure. The blowby on mine went up a fair share with the increase in boost levels.
J-eh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 LSD Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
237,500 miles (380,000 Kms) 7850 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics 07-00
I took a rubber grommet-mounted K&N style breather filter and just screwed it into the filler tube. Works fine and cost less than $20. Got it at Pep Boys or Discount Auto; don't remember which!
Jesus</A> saves!
