Engine/Transmission (1994 - 1998) Replaced Tstat
Engine/Transmission (1994 - 1998) tire question
Well I guess you would say I got introduced a little to my engine today. I replaced the tstat. I was flat amazed at how easy it was, man that was slicker than snot - whip, bam, boom I was done. Now what I did was get both seals and tstat from local Cummins dealer, I did not get the updated part number. As I noticed on a thread posted here (can't seem to find it now but anyhoo) that the updated tstat runs a little cooler and takes longer to heat up. Well I'm a little cold blooded and want heat and want it now. So I decieded that I would see what the swinging water temps were like as long as I have heat heat heat.
What prompted this was she was leaking up by the tstat housing, just purchased truck last weekend and previous owner said tsat seeped a little. His little and my holy snickles it leaks are the same level, but then again I get all bend out of shape at a drop of any fluid.
I tore the housing apart and seen how it goes together, sort of sandwiching the lifting eye inbetween the tstat housing and head. I just sort of shook my head thinking to myself I could loose the lifting eye and probably be better off, I mean one less surface has to be a good thing. I did not remove it but cleaned it up a bit with a razor then smeared some smurf poop on there just keep any "I think I can" leaks at bay. There were not signs of smurf poop from a previous installation so I don't know if I did bad thing or not. I also noticed that when I took out the bottom bolt (gotta love how easy that thing is to reach - NOT!) that there was wetness associated with the threads, so I smeared those up as well. Don't know if the threads actually reach into a cooling cavitity but figured it would not hurt.
I have not ran her out yet but I got my fingers crossed and I'm looking for chicken to appease the diesel gods. My fear is that the leak is actually a head gasket and not the tstat housing but I did see some rust on the mating surfaces of the lifting eye (both sides) so I suspect this was the root problem.
I think I spend around 30 mins with the hood up total - this even included me farting around looking for my fender covers in the garage - I hate it when I get a bug up my butt and shuffle stuff around in the garage - I can never find anything the next time I'm working on something.
Oh well all in all it was a good introduction to my new to me truck.
Yep a heck of a lot easier than the IDI.
Loaded the family up yesterday after the repairs were done and when for a drive in the country side. Boy does that temp ever swing - eek! but the heat was wonderful and she heats right up (this will come in handy about mid Jan when the temps are really down there). Did not see any leaks but will keep an eye on here for a few more days before I call it a done job.
argve said:
p this will come in handy about mid Jan when the temps are really down there
Aww common! Indiana is MUCH warmer than we are up here in January!
:D :-laf I know what you mean about the heat though. I have the updated T-stat... . and compaired to my old stuck open T-stat it's GREAT!
Josh
