Replacement fluids
Any one have JPEGS of AFE Stage 1 in a 03' truck?
2005 B-dog Power Pup?
It is almost time to change the diff's and t-case fluids. What is everyone using or recommended. Was thinking of going full synthetic. Also when is it recommended to change the transmission fluid?
Thanx in advance for the help.
For the diffs I'm using Mobil 1 synthetic 75w90. It meets all the required specs and doesn't stink/chatter like the Amsoil series 2000 I used. Several folks will report using the amsoil with no problems, but several also do. For the T-case and transmission, the service interval is 30k. You can do a search on the proper transmission fluid. Again, many people use Amsoil with no problems, but for trans fluid most stick with the mopar stuff.
