Some time ago I relocated the lift pump to the frame and up-graded to a Carter 4601HP pump that is supposted to be good for 18psi. The original 4601HP had 12psi @ idle and 6psi @ WOT and lasted about 1. 5 years, when it started to loose pressure. Back to NAPA for a new pump and it only held 9psi @ idle. Back to NAPA again and they gladly replaced it with a new 4601HP. Same problem, only 9psi @ idle. I have a 3/8 draw straw and 3/8 Gates rubber hose all the way foward. Checked also for any kinks or restrictions. I'm stumped, need some advise. Thanks, Ponz
