Replacement Tie Rods
No low beams turning off high beams
Changing rearend differential
Do any of you know if there is any one that makes full replacement tie rod ends for our truck? Will ones from a 97 fit? None of the parts stores around here have a listing for them, and don't want to buy any dodge junk, trying to get all the dodge out as it is. Any help would be appreciated.
Morph
Try the Luke's Link to fix yours. NAPA told me they are in the process of making a tie rod set-up for the 2500 4x4 that will let you change just the tie rod on either side, but I don't think it is available yet. Search for Luke's Link and you will find a thread with the web address and a good description.
