I just joined the club of Dodge owners with a failed TC stator sprag. Like many posts I've read, mine started not long after a transmission service. Bought the truck in Jan with 90k miles. Had transmission serviced with a flush, filter change, and band adjustment. Less than 1500 miles later, the sprag clutch failed, suddenly. Slowing below 5 MPH became difficult, and both engine idle and turbo speed would increase approaching a stop. I never waited to see what would happen..it felt wrong, so I just shifted to Neutral. Other than a TC drainback change, there was no abnormal behavior prior to this failure. In fact, (stock) shifts had been noticeably better since the service. When cold, it seemed to prefer a 10-15 sec delay after start in neutral prior to selecting drive. I did not notice this drainback issue before the service. Maybe the check valve was fouled, who knows?
Back to to the point- I am leaning towards a Goerend GT TRPL TC 4748RE 3 disk billet cover model to replace the poorly designed stock TC. My question involves driving characteristics of the 15SS (200-400 r/m lower stall) vs 17SS "stock stall" options.
I haul kids, commute, and occasionally tow moderate weight trailers long distances (boats, bovines, etc). Your opinions are requested for my stall speed choice. I haven't added power yet. If I tune, it would be for towing and/or mileage. Will mileage be noticeably affected by stock stall vs lower stall? Any thoughts on driveability with these two options? Longevity?
Input appreciated. I've read only positive things about this manufacturer. Any input along those lines should perhaps be a PM, considering the new guidance.
Thanks!
Thanks!
