I've swapped my backup lights with dual purpose led bulbs(Feniex Cannons). They are used as a hideaway strobe type bulb, and anytime the truck switches into reverse they go to steady on. If I switch them into "warning mode" they alternately flash (until I switch to reverse or turn them off).
Question is: There are three ways RAM approves to do this per their upfitter specs. One is by going through the VISM (not equipped) two, adding resistors, and third cutting and grounding a wire at the CBC.
MY preference is the CBC grounded wire. I'm not a huge fan of resistors either.
According to this document, how should I proceed. I'm completely lost.
Any help is appreciated.
http://www.rambodybuilder.com/iph/iph2013/ph2013/phdocs/phram/phextlitmod.pdf
Craig
Craig
