2nd Gen Non-Engine/Transmission Replacing factory stereo w/infinity system
I need to replace the factory installed cd cassette head unit, but I've heard that the stock speakers have some sort of amplifier built into them and that aftermarket head units wont work with the OEM speakers? Has anyone replaced the infinity system? (It sure wasnt worth the $500. 00 they charge for it... )
not true. i installed a pioneer unit to get xm radio . all you need to do is hook up the signal wire to turn on the amps. it is a blue wire . you use the ant power lead from the radio to activate the amps. use the sub harness to hook it up so you dont cut factory wiring and wire the ant wire to the amps .
sort of.....
the stock speakers will work with aftermarket heads but to replace the speakers will NOT work with the OEM head.
replaced my OEM AM/FM/CD with an Alpine and it sounds so much better...
still toying with adding a sub and an amp... but there's more i want to do with limited funds.
