Hello. I have read numerous threads about the "KDP" fix, but I need to fix the results of a KDP. It backed out years ago, right after getting the truck used. I JB Welded the the crack, replaced the front cover gasket and the crankshaft seal and it has been fine for nearly 100,000 miles. Truck is now one of our company service trucks and has developed a major oil leak somewhat suddenly. Our service guy removed the front cover, resealed the area around the housing crack and packed everything as full of silicone as he could, which slowed the leak. He also resealed the vacuum pump and replaced the gasket where the vacuum pump mounts to the engine. I am thinking the gear case has developed another crack near the injection pump. What all parts will I need to get and what are the part numbers? Also, any tips about removing the cam would be greatly appreciated. We are not willing to tackle the gear removal and installation, but instead want to do the whole cam shaft. Thanks for any advice. Per searching threads here, I found the following part numbers:
Gear case: 3936256
Gear case gasket: 3938156
Front cover gasket: 3918673
I will also need the following and would appreciate part numbers if yall have them:
Injection pump mount gasket
Vacuum pump mount gasket
Fuel transfer pump gasket
Front crankshaft seal
Valve cover gaskets
Valve cover washers
Thanks again and please fill me in with anything else I may be forgetting.
John
Gear case: 3936256
Valve cover gaskets
Valve cover washers
John
