Originally posted by Joseph Donnelly
If possible, have the trans pointed with the input vertical. Remove the 4 bolts holding the front bearing retainer, pull it out, then the gear will come right out. It has a caged roller bearing inside it, and a flat needle bearing between it and the mainshaft assembly. You don't want the flat bearing to fall off which it might if the trans were held in its installed position while removing the input. Afterwards, it is a good idea to check the end play on the mainshaft; it should be 0. 002-0. 006 dry; you might get 0. 001-002 less movement oiled.
Started putting the McLeod dual clutches back together last night and noticed that the hubs are bent! So, I guess I'll need to find some new clutches or go with a different type clutch...
A question for anyone that has done the fifth gear fix - I got the split nut from Standard Transmission and installed it last night. I may have missed a step however during the installation. I did not tighten the cross bolt down and back it off one turn before I cranked the nut down on the gear. After I torqued the cross bolt down to 10ft lbs, I ended up with . 170" clearance on the opening of the split nut. Is this excessive?
